testing the d16y8 distributor. need help with a link.
i tried to do a search and im pretty bad at it.
im looking for the instruction/spec on testing out the distributor.
d16y8 distributor. civic 1998ish EX model.
links with pictures is a plus as i am more visual.
i need to test the whole dizzy and need the OHM and other instruction to test the:
ignition coil,
TDC / crank cyl sensor,
and anything else that should be tested
before i take it out and replaced.
thanks.
ignition coil,
thanks.
Re: testing the d16y8 distributor. need help with a link.
Ohm testing coil and voltage testing distributor - see diagrams in FAQs sticky
Ohm testing 3 distributor sensors - spec = 350-700 Ohms
i tried the faq. it looks like its for the 91 dizzy specs. i already have the manual book for that year.
i thought that 92+ would differ.
rhdekhatchie
01-23-2008 10:04 AM
NACvicSi
12-21-2005 03:34 PM
