Engine Harness Deadend Plug issue
Old Jul 10, 2012 | 08:44 PM
SAMCRO08's Avatar
Default Engine Harness Deadend Plug issue
I bought a Rywire harness from a friend of mine and he was feeding it through the heater core of a 95 civic and he said the dead end connector with the yellow and black wires was cut off because it wouldnt fit...car never started of course and he sold me the harness for cheap and he gave me the plug he cut. the issue it that id like to connect the chopped off plug back but the yellow and black wires look the same. How do i go about fixing this issue
Old Jul 11, 2012 | 01:21 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Engine Harness Deadend Plug issue
Post pics
Old Jul 11, 2012 | 07:35 AM
Former User's Avatar
It's called a junction connector. It shouldn't matter what order you reconnect the wires as long as you match wire colors.
Old Jul 11, 2012 | 07:24 PM
SAMCRO08's Avatar
RonJ@HT what does a junction connector do? could that be the cause of the fuel pump not coming on and ignition not coming on when my friend turned the key? He would get power on the dash but thats it
Old Jul 11, 2012 | 08:30 PM
Rather than splice multiple wires together, Honda uses junction connectors to distribute power or ground from a single source to multiple electrical components.
yes
Old Jul 12, 2012 | 06:13 AM
SAMCRO08's Avatar
RonJ@HT thanks for the info, so when i look at the connector i have 9 black wires (im guessing grounds) and 7 yellow wires all the same yellow with no stripes or markings on them ( im guessing power) You said just reconnect proper wires to there colors? cause some of the wires have like 2 wires going into one pin. I just dont want to put a wire in the wrong place
Old Jul 12, 2012 | 06:34 AM
Post pictures of the connector.
Old Jul 12, 2012 | 04:50 PM
SAMCRO08's Avatar
heres the dead end plug
Old Jul 12, 2012 | 05:13 PM
The Yel/Blk wires may supply voltage from the main relay to the 4 fuel injectors, the IACV, the O2 sensor, and the EVAP purge valve.
Old Jul 12, 2012 | 05:32 PM
SAMCRO08's Avatar
can i reconnect them to the harness it came from by using any black and any yellow? Like u said
Old Jul 12, 2012 | 05:36 PM
Yes
Old Jul 12, 2012 | 05:39 PM
SAMCRO08's Avatar
thanks...so it wouldnt short anything out correct?
Old Jul 12, 2012 | 05:41 PM
Disconnect battery.
Match Yel/Blk to Yel/Blk
and
Match Blk to Blk
Order is unimportant
Use solder and shrink wrap.
Old Jul 12, 2012 | 05:47 PM
EF9_TryMe's Avatar
No you will not short anything out. They are junction connectors, if
you look at the lead constructed in the plastic female connector you
can clearly see that there is a pattern to this wiring. The same color
wires share the same circuit. Look at the lead on the junction
connector, you will find out yourself.
Old Jul 12, 2012 | 05:55 PM
SAMCRO08's Avatar
thank you all very much
94-integra-ls
Sep 17, 2009 05:23 AM
KDvtec5757
Jul 13, 2009 04:49 PM
93egboosted
Mar 18, 2009 07:27 PM
WickedWerx
Nov 1, 2004 08:18 PM
Jonathan_ED3
Jun 21, 2003 04:16 PM
