98 civic/B18b1 swap - 3-wire to 2-wire IACV conversion and idling issue
i have been having a problem with my idling on my 98 civic, also a problem with not being able to keep steady speeds. i know this is all symptoms of the 3 wire iacv to 2 wire. i did the conversion and still have the same problem. i have a 98 hatch with a b18b1 motor with a obd2a to obd2b jumper harness too fyi. someone help!!!
Re: ek civic idling issue
i checked it multiple times. i did mine like this http://hondaswap.com/attachments/6d1...15-iacvfix.jpg i didnt know if the obd2a to obd2b harness had anything to do with it
Are you saying that even if there were an IACV circuit problem, code 14 would not be thrown?
Describe your wire conversion in detail. Post pictures.
Same issue with mine, b18c1 into 96 CX, 5-speed swap. Had an LS before. NO issues. Used the iacv from ls and the gsr started surging, no codes were thrown. So... I mad a blockoff plate between the iacv and intake mani...
Fix the wire issue after your obd2b connector which means your starting with the obd2a
harness. The jumper harness linked to obd2b is going to automatically compensate for
this once you wire up the IACV to the original car harness(obd2a.)
ok so i cut the A13 wire and just left it alone. i cut the A14 wire and wired it directly to the wire on the other side of A12. should just be that simple right?
Problem 1) There should be two Blk/Blu wires spliced together at the A12 pin, but I don't see that in your picture. I instead see two Blu wires spliced together at that pin. Below is a clear illustration of what needs to be done at the OBD2a ECU connector.
Problem 2) You are not showing us how you spliced the IACV connector wires.
Problem 3) You need to solder and heat shrink insulate the spliced wires. Your wire splicing job is unacceptably sloppy. Why did you also splice a Grn wire to to a Blk wire in the picture?
Re: 98 civic/B18b1 swap - 3-wire to 2-wire IACV conversion and idling issue
The black/blue wire is the A14 wire. Its connected to thr other side of A12. Its green because the jumper harness is green. Sorry i should of put a better picture up. Also thr blue eires disregard those. That was a ccident, i cut the wrong one lol
You have not shown us how you spliced the IACV connector wires.
here are some pictures to hopefully help? i could not get a picture of the actual wiring at the iacv because it is all shrink wrapped and tucked under the manifold. the wires by the ecu are not taped up/ or shrinked wrapped yet because i was just testing it to see if it would work. once its idles fine then yes it will get soldered and heat shrinked
The A14 splice is the main concern. The A14 Blk/Blu wire should be moved to A12. Instead, it appears that you bypassed the OBD2a connector and spliced the A14 Blk/Blu wire to a green wire from the conversion harness. Is this correct? Why did you do this? The problem is that I cannot verify that you chose the correct green wire to splice with the A14 wire because you have not described how you made this choice.
We can also only assume that the IACV connector splicing was done correctly.
Finally, a bad IACV conversion is expected to throw code 14, but there is no code. Why?
i picked the wire that was directly behind the A12. and just moved the A14 directly to there. also yes with the aem ems for some reason no check engine light comes up even though i know i do have a check engine code. the next step ill probably have to take is removing the manifold and take some pics of the iacv wiring for you. i know its kinda hard to help me lol
i just assumed it was the iacv i guess. i cant keep steady speeds, and when i unplug the iacv it does nothing.
When you have technical problems, assumptions are very dangerous and often delay pinpointing the problem. If code 14 is not thrown, then you are most likely on the wrong track.
