1993 civic wont start
i have a 93 civic sedan that wont start
it cranks but wont start
fuel pump is pumping
timing belt ios moving
its getting spark
i dont know how to chek the dizzy itself
could some one help me please
its getting spark
ok then...... unplug one of your fuel injectors .. then take the paper clip and stick it in one pin of the connector......then clip the test light onto it....then stick the light on the other terminal... Then you turn the key on the test light should stay on... then when you crank it you should see the test light flicker....this voltage that you are seeing as a flash is refered to a pulse...try this and lemme know what happens..
Im having the same problem with my 93 civic its gettin spark and fuel but still not start ive checked the main relay and its workin..what else can stop the car from fully turnin all the way over?
MikeVDP
Jul 9, 2016 02:38 PM
civic_driver09a
Audio / Security / Video
25
Nov 16, 2009 11:41 AM
michael_antoi
Jan 15, 2006 12:47 PM
Ratoncito
Jun 28, 2004 01:31 PM
and if its gettin spark the dizzy is fine..it "distributes" the spark....
