i need help asap. intake mani. SEARCHED
Old Nov 7, 2008 | 09:21 AM
iheartmyej8's Avatar
Default i need help asap. intake mani. SEARCHED
can i use a 93 dx intake mani (normal style mani) on a 97 y7 motor? i need help asap
Old Nov 7, 2008 | 09:31 AM
halocore's Avatar
Default Re: i need help asap. intake mani. SEARCHED (iheartmyej8)
you should be able to, as from what i heard, all d series engine parts are interchangable
Old Nov 7, 2008 | 09:47 AM
davefromPA's Avatar
Default Re: i need help asap. intake mani. SEARCHED (halocore)
you can but you will have problems with certain sensors. 94eg8 will be able to help you through the process but in simple, yes it will fit.
Old Nov 7, 2008 | 11:51 AM
Default Re: i need help asap. intake mani. SEARCHED (davefromPA)
well the y7 isgoing into the dx. so we was going to just change the manifold over to the y7 and run the obd1 sensors/tb/intake.
Old Nov 7, 2008 | 11:54 AM
davefromPA's Avatar
wouldnt you rather have a z6 intake then?
Old Nov 7, 2008 | 12:07 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyej8 &raquo;</TD></TR><TR><TD CLASS="quote">can i use a 93 dx intake mani (normal style mani) on a 97 y7 motor? i need help asap</TD></TR></TABLE>
I can only assume, especially based on the posts below that this is going in a '93 DX. If this is the case reuse the '93 intake and exhaust manifolds, alternator and distributor (note, the D15B7 distributor is supposed to bolt up to a Y7 head, but i've never personally tried it, if it doesn't swap the CYP/CKP/TDC sensors out the D15B7 distributor into the Y7 case, again though i'm quite sure the whole distributor just bolts on. You will have couple of wires comming from the oil pump for the CKF sensor on the Y7, simply tie them up out of the way.
Old Nov 8, 2008 | 12:18 AM
Default Re: i need help asap. intake mani. SEARCHED (94EG8)
well we just got the car runnning. swap went good, but the intake mani i believe is a fail. lol. its leaking from a wierd spot. and its hard to explan. but on the 93 dx motor, in the head, has a square hole(im assuming for antifreeze recirculation). the y7 motor has a round hole thats blocked off. and now its leaking there. the y7 dont have the recirculation.
as far as all the other stuff, (sensors, dizzy exhaust) we just transfered to the dx motor.
but for some reason the clutch isnt working. we used the dx slave cyclinder on the y7 tranny. any help? the petal goes straigh to the floor and dont come back up. do i need to bleed the clutch lines?
Old Nov 8, 2008 | 06:06 AM
94EG8's Avatar
Seagull Management
did you disconnect the slave cylinder from the line at any point?
boosted 95 coupe
Feb 12, 2007 04:22 AM
skrappy
Jan 8, 2004 04:19 PM
Blaze45
Jul 31, 2003 06:35 PM
RicedREX
Nov 3, 2002 09:28 PM
