ignition output signal CEL #15
hey guys i had a code 9 the other day CYP sensor (cyl 1 sensor), so i bought and installed a new dizzy from AZ and i was driving home and my car just shut off and a code 15 popped up. I think there may be a wiring problem near my ecu, so i checked those wires out and fixed a couple.
Cliff notes:
95 del sol si (jdm sohc vtec JDMd15b obd1)
car wont start (but will everyonce in a while when i tinker with the wires but shuts off
CEL #15 ignition output signal
anyone have some expertise?
Cliff notes:
Here's where to concentrate:
1) The igniter may be bad.
2) The Yel/Grn wire between the igniter and ECU may be bad (open or short).
3) The Blk/Yel wire between distributor 2P connector and ignition switch may be bad. There should be battery voltage with the key turned to ON(II).
yeah all of my wires are hacked to bits around that area by my ECU. I tried using a different ECU as well...
sounds like im going to need a mutimeter, i checked for power at the yellow/green wire using a lightbulb and ground and it looks like theres power there (maybe insufficient though???), i literally had just replaced the dizzy when this **** happened and i was driving away from autozone, so im not thinkin its the dizzy too much since its new...
Does the Blk/Yel wire in the distributor have battery voltage with the key in ON(II)?
Does the Yel/Grn wire running between the igniter unit and ECU have continuity? What voltage does this wire have at the igniter unit with the key in ON(II)?
the cars at a friends house and hes working on it but he hasnt been about to figure anything out...ima text him what u wrote...what if the blk/yel wire in the dizzy has voltage?
