Gauges and turn signals won't work
Old Nov 6, 2008 | 11:44 AM
soisauce's Avatar
Default Gauges and turn signals won't work
I have a 93 civic ex coupe mt, as I was driving I hit the turn signal and my gauges went dead. Now the gauges wont move and turn signals do nothing, the hazards work though. At first I thought it was the relay or the light indicator switch, changed both but still nothing.. I relize now that I have a short somewhere, because of the fact the hazard fuse keeps popping. I'm using a test light but i can't seem to find the problem.. any suggestion on where to look?
Modified by soisauce at 2:54 PM 11/6/2008
Old Nov 6, 2008 | 12:08 PM
Former User's Avatar
Default Re: Gauges and turn signals won't work (soisauce)
You may have a short in the hazard switch. The turn signal circuit passes through the hazard switch.
Old Nov 6, 2008 | 12:22 PM
soisauce's Avatar
Default Re: Gauges and turn signals won't work (RonJ@HT)
So it could be the switch itself?
Old Nov 6, 2008 | 12:32 PM
You already replaced the turn signal switch. Right?
If so, the hazard switch might be the problem. Here's how to test:
Old Nov 6, 2008 | 02:14 PM
soisauce's Avatar
Hazard light switch is working properly, and yes i changed the turn signal switch,I don't know where to go from here............ Btw when I turn on the car the check engine light usually comes on then turns off, but it does not even come on anymore, also my clock won't come on.
Old Nov 6, 2008 | 03:09 PM
The turn signals work through the hazard switch when it is in the OFF position. The hazards operate in the ON position. Therefore, the short may only occur with the hazard switch OFF and one of the turn signals ON. As shown in the diagram, testing the hazard switch is pretty easy.
With respect to the CEL and clock problem, fuse 32 under the hood is probably blown.
GabeBellaflores
Jan 16, 2019 02:15 PM
Meraut
Mar 11, 2013 06:34 AM
amb4081
Nov 21, 2012 07:29 AM
egboy94
Feb 26, 2011 05:52 AM
Shocka1998LX
Nov 18, 2008 12:50 PM
