D16Z6 MAP AND TPS Connectors
Ok the question I have is are the connectors the same? I know they hook up the same with 3 pins 3 wires, but I just got an EG with the D16 swap and I'm throwing a MAP CEL. When I looked someone has a TPS connector on the MAP sensor meaning both the TPS and the MAP sensor both have the same 3 color wires coming out and the MAP splices in (hardwired) to the MAP side of the harness.
Basically both plugs have a TPS plug on them will this cause me to throw a MAP CEL or are they interchangable as long as the wires are mated ie. power, ground, signal.
ENJOI
11
Aug 23, 2006 10:39 AM
