VSS not working??
Old Nov 6, 2008 | 08:18 AM
lmgsr's Avatar
Default VSS not working??
Hey HT. I have an EG at first the speed sensor was working, then it stopped working. Then it would work for a while then stop again. I put another speed sensor from my GSR and it still wasn't working I put another cluster and it still wasn't working. So I put back the original cluster on it. I started checking the VSS harness and found out that one of the pins wasn't going in all the way, so I pushed it in and when I plugged the harness in the pin would come out again. So I removed the pins from the plug and connected them to the VSS. Thats when I had my other issue on my previous thread (already fixed). But now I looked at the ground wire and the pin looks darker than the other two. So I thought it could had shorted out. So I connected a ground wire directly from the thermostat ground housing and I still can't get the speedometer to work. So I don't know what it could be. Any ideas?
Sorry for the long story just wanted to let you know exactly everything in case I'm missing out something.
Thanks for all the help in advance.
Old Nov 6, 2008 | 10:23 AM
lmgsr's Avatar
ttt
Old Nov 6, 2008 | 02:30 PM
lmgsr's Avatar
bump
hondaB
10
May 10, 2011 11:10 AM
foxdecoy
Aug 21, 2009 03:41 PM
ONEhaque
Nov 4, 2008 06:31 PM
ULTRAdC2
Feb 1, 2007 05:27 PM
snackpack
Dec 18, 2006 02:39 PM
