How safe to drive on 3 studs?
Old Nov 5, 2008 | 08:28 AM
Xathine's Avatar
Default How safe to drive on 3 studs?
[freak]ing have a broken wheel stud. [freak] theifs.
I've gotta drive the car 120 miles to get it home from the shop its sitting at.
Doesn't sound to safe, any input?
Rtaher not have to tow it
Old Nov 5, 2008 | 08:32 AM
irollerblade's Avatar
I drove on three studs for like 6 months and I was fine.
Xathine's Avatar
Default Re: (irollerblade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irollerblade &raquo;</TD></TR><TR><TD CLASS="quote">I drove on three studs for like 6 months and I was fine.</TD></TR></TABLE>
highway?
I'm rather low as well
Old Nov 5, 2008 | 08:35 AM
dafuzzbudd's Avatar
Default Re: How safe to drive on 3 studs? (Xathine)
ive driven on 2 per wheel taking my car back from the junkyard. i think three for a short period will be ohk.
o0o didnt read. i road on 2 lugs. not sure about studs. maybe pull into a parking lot and fix it there? maybe pull it into a pepboys and let them fix it?
Old Nov 5, 2008 | 08:36 AM
wrenchez81's Avatar
Default Re: (Xathine)
thats a very easy way to warp rotors and drums... but in short term you will be ok... even on the hwy...
rpared01's Avatar
you should ok, just make sure that other 3 are torque down to spec and just drive home smoothly.
Old Nov 5, 2008 | 08:48 AM
wrenchez81's Avatar
Default Re: (wrenchez81)
^^^ 80 ft lbs!!!
Old Nov 5, 2008 | 08:57 AM
Yeah my car was slammed and I had a h22 in it and I would punch it now and then and it was fine.
Old Nov 5, 2008 | 09:04 AM
Relic1's Avatar
obviously not recommended, but thinking logically, the for/aft forces are not near as much of an issue as the side to side forces.
So baby the car, avoid pot holes and rough sections of road, slow down for corners, and you should be ok.
Old Nov 5, 2008 | 09:34 AM
Turbo_5.0's Avatar
Modified by HybridcivicLS-T at 1:48 PM 11/5/2008
Old Nov 5, 2008 | 09:37 AM
alphalanos's Avatar
Default Re: (Turbo_5.0)
^^ Seems like another awesome new guy.
Old Nov 5, 2008 | 09:42 AM
nix94delsol's Avatar
Default Re: (alphalanos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">^^ Seems like another awesome new guy.</TD></TR></TABLE>
lol, on the first day god made honda-tech, the second he created haters, the third, he took a ****, and called it the "wanna be" hater
Old Nov 5, 2008 | 09:44 AM
slo_hatch's Avatar
x2...some of the new people are smartasses.
OP: you should be fine...just dont drive too fast and avoid potholes and such. i haave been driving my coupe on 3 lugs (i know its not the same but its close enough. ) for the 8 months i have owned it i thing. lol 3 lugnuts are jdm yo....
Old Nov 5, 2008 | 10:31 AM
dividedas1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_5.0 &raquo;</TD></TR><TR><TD CLASS="quote">Do it... And see if that wheel falls off. It'll be great. Make sure you torque the other ones down with an airgun, you'll be fine hehehehehe..</TD></TR></TABLE>
he's obviously retarded... most people that "torque" down lugs with air guns end up having studs break from... oh let me guess, being over torqued.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrenchez81 &raquo;</TD></TR><TR><TD CLASS="quote">^^^ 80 ft lbs!!!</TD></TR></TABLE>
ftw
to the OP you will be fine just like people said avoid pot holes, sharp fast turns and just baby your car and you will be okay.
Old Nov 5, 2008 | 10:38 AM
dapek's Avatar
I drove my rhd from San Diego to Bellingham, Wa. 26 hours straight there with a broken rear wheels stud, so i'd say you'd be fine...but what do i know
Old Nov 5, 2008 | 10:46 AM
94EG8's Avatar
Seagull Management
you should be fine.
And as for tightening lug nuts with an impact, they generally don't tighten properly, especially aluminum wheels. You can tighten them with the impact, then put the socket on a bar and still get them to tighten quite a bit more.
Old Nov 5, 2008 | 11:29 AM
dividedas1's Avatar
Default Re: How safe to drive on 3 studs? (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">you should be fine.
And as for tightening lug nuts with an impact, they generally don't tighten properly, especially aluminum wheels. You can tighten them with the impact, then put the socket on a bar and still get them to tighten quite a bit more.</TD></TR></TABLE>
how hard is it to just torque them to spec tho.. seriously. 80 ft lbs is not that much... at all. idk maybe i am just too over cautious about my car but i think i would rather just torque my lugs to spec and be done with it. honda obviously knew what they were doing when the made the specs.
Old Nov 5, 2008 | 12:44 PM
sintype's Avatar
just drive safe.
Old Nov 5, 2008 | 12:50 PM
wrenchez81's Avatar
Default Re: (sintype)
actually when you overtighten lugnuts you then stretch the threads and cross thread them trying to take it off!!! i bet thats how the stud broke ta begin with
incredteg3
Sep 3, 2007 05:08 AM
All-Motor-Junkie
Sep 14, 2006 07:16 AM
Markis.
16
May 23, 2005 01:28 PM
bemathew
Aug 16, 2004 01:02 AM
R THIS
Apr 20, 2004 07:05 PM
