Help with swapping a LS in my EG
I am planing on buying the tranny/passenger side mount and the rear mount since I already have the driver side 1. I wanted to know if I need to get the lower mount on the front of the transmission or if I don't need to use that mount. Also I read there was a mount on the rear of my stock d15 transmission that I can use on the LS is that so or do I need to get the integra one? This is my first swap in my first car and I am trying to do it alone with the help of some friends. I read the FAQ and all that and it doesn't specify if I need them or not and I am a little confused about the torque mounts.
Thanks.
Modified by Ya Digg at 11:11 PM 11/5/2008
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyfeat2006 »</TD></TR><TR><TD CLASS="quote">Your going to need all B series mounts and the rear T-Bracket. </TD></TR></TABLE> Do I need to get the braket on the lower front of the transmission. I think its a torque mount that has 3 bolts on it and it connects to the frame..?.?..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ya Digg »</TD></TR><TR><TD CLASS="quote"> Do I need to get the braket on the lower front of the transmission. I think its a torque mount that has 3 bolts on it and it connects to the frame..?.?..</TD></TR></TABLE>
If you're planning to run torque mounts (recomended) then yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">What year is the LS swap? B18A or B18B?
Help me help you.
</TD></TR></TABLE> Ok its a 2001 b18b1
Help me help you.
Assume 5-speed for the following:
1. Timing side bracket (bolted to block already) and mount - 94-01 Integra
2. Rear t-bracket - 94-01 Integra
3. Rear mount itself - 92-95 Civic or 94-01 Integra
4. Topside transmission mount/bracket - 92-95 Civic or 94-01 Integra
5. Front tranny bracket - 94-01 Integra
6. A/C bracket - if keeping a/c use either 94-97 Del Sol VTEC or 97 CR-V a/c bracket; if no a/c use 94-01 bracket
7. Front lower anti-roll mounts - 92-95 CIVIC - I bolded these because many people say use the Integra ones, but they do not sit flush with the Civic frame rails like the Civic mounts do
What year/make/model is the car?
I strongly suggest using the 01 Integra engine harness as it will greatly reduce wiring and swapping of key parts to make them plug into the EG engine harness.
Help us help you.
Help us help you.
I have a 95' civic CX and I have the harness from the LS and its connects directly to my shock tower harness.
I am gonna look for pictures of these, if anybody wants to post pics of them mounted please do so.
Modified by Ya Digg at 11:30 PM 11/5/2008
I have the brackets you need...I'll sell u all the motor mounts, tranny mount, torque mount and T bracket for $100 if you meet me halfway. PM me if you want my cell #. Your boy got those steelies and sideskirts off me. LMK asap.
stackz
Nov 6, 2006 03:30 AM
endlesswinterco
Nov 17, 2003 08:47 PM
