eg door panels?
I'm trying to remove the door panels on an eg hatch to do a speaker install and to replace/fix the door handles. Im used to workin with ef's so I dont know where to start poppin off the panel. I already see a few screws, but I dont want to "break" any brackets lol.. Anyone who knows how to do this, let me know. I know it should be pretty quick and straight foward, so any info would be greatly appreciated
take the cover off where the speaker goes and take the screws ou...then pull the bottom and get that loose...then pull up and get it off. should be very easy...if it has power anything just unplug it. if not...it should be straight forward. the hardest part will be the window crank (if it is manual windows). hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch »</TD></TR><TR><TD CLASS="quote">take the cover off where the speaker goes and take the screws ou...then pull the bottom and get that loose...then pull up and get it off. should be very easy...if it has power anything just unplug it. if not...it should be straight forward. the hardest part will be the window crank (if it is manual windows). hope that helps.</TD></TR></TABLE>
screws for the speaker bracket or screws that holds down the door panel?
The top 2 screws are pretty much impossible to get to without taking off the panel. There is no way I can get a phillips screwdriver up in there...
There is this little bracket though that I see that is kinda round and is by the speaker panel. How do I go about in shimmying the panel out of that bracket? Is this where I pull up?
And yes it is manual windows... How do I go abt getting out the window crank? It seems like its stuck in there lol
SLURS
13
Jun 18, 2009 01:39 AM
93eh2hatch
Dec 18, 2007 04:50 PM
