LS SWAP IN A EG!
Old Nov 5, 2008 | 08:50 AM
hondaEg_808's Avatar
Default LS SWAP IN A EG!
hey guys! i have a question? im going to pick up a 91 integra gs with a ls motor and the head as been port and polished but the bottom block has a hole in the 4 cylinder wall! so i was wondering if i could take the head off the ls and put it on another ls motor because i have another one on the side! and the reason why im grabbing the whole gs is beacuse my sohc in my eg is blown and the car has all the parts i need to do a b series swap! well i wanna know if i can take the parts off the gs and complete my swap! if you guys can help me that would be really appreciated!! thanks guys!
Old Nov 5, 2008 | 08:53 AM
jdmeg6rsk's Avatar
ur gunna need a hydro tranny not cable
SOHC_4dr's Avatar
Default Re: LS SWAP IN A EG! (hondaEg_808)
an LS head on a LS block? wow i didnt know you could do that
Old Nov 5, 2008 | 08:54 AM
Default Re: (jdmeg6rsk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6rsk &raquo;</TD></TR><TR><TD CLASS="quote">ur gunna need a hydro tranny not cable</TD></TR></TABLE>
i have a b-16 hydro on the side!
Old Nov 5, 2008 | 08:56 AM
Default Re: LS SWAP IN A EG! (SOHC_4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_4dr &raquo;</TD></TR><TR><TD CLASS="quote">an LS head on a LS block? wow i didnt know you could do that </TD></TR></TABLE>
well i know that but what i was trying to say is that since there is a hole in the cylinder wall should i be worried that the head can be messed up?
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaEg_808 &raquo;</TD></TR><TR><TD CLASS="quote">the reason why im grabbing the whole gs is beacuse my sohc in my eg is blown and the car has all the parts i need to do a b series swap!</TD></TR></TABLE>
Don't buy it, you're not going to be any further ahead, you will still need a tranny ('90 - '93 integra trannys use a cable clutch as opposed to the '92 - '95 civics and '94 - '01 integras use a hydraulic clutch. You will also still need an ECU (Pre '92 ECUs are OBD0, '92 - '95 are OBD1
Old Nov 5, 2008 | 08:58 AM
SOHC_4dr's Avatar
look the head over really good. take it to a machine shop if you want and they can use magnaflux to look for cracks in the head or anywhere else. there are other things you can use to to check to but i cant think of them right now
Old Nov 5, 2008 | 09:00 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaEg_808 &raquo;</TD></TR><TR><TD CLASS="quote">well i know that but what i was trying to say is that since there is a hole in the cylinder wall should i be worried that the head can be messed up?</TD></TR></TABLE>
It could be messed up, theres not really anyway of knowing until you pull the head, i've definately seen it happen though, rod broke, piston came up and hit the head. '90 - '91 B18A heads don't flow particularly well if i remember correctly btw. those engines only put out 130HP at the crank. the '92 - '93s are rated a little better at 140HP.
Old Nov 5, 2008 | 09:23 AM
Default Re: LS SWAP IN A EG! (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">
Don't buy it, you're not going to be any further ahead, you will still need a tranny ('90 - '93 integra trannys use a cable clutch as opposed to the '92 - '95 civics and '94 - '01 integras use a hydraulic clutch. You will also still need an ECU (Pre '92 ECUs are OBD0, '92 - '95 are OBD1</TD></TR></TABLE>
well i have a b16 hydro on the side! and i also have 2 other ls motrs on the side so basically i have 3 three altogther including the one in the car! i got the whole car and 2 ls motors for 500! but i needed the gs because i need the axels and shift linkage and other stuff also!
Old Nov 5, 2008 | 09:25 AM
Default Re: (SOHC_4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_4dr &raquo;</TD></TR><TR><TD CLASS="quote">look the head over really good. take it to a machine shop if you want and they can use magnaflux to look for cracks in the head or anywhere else. there are other things you can use to to check to but i cant think of them right now</TD></TR></TABLE> so something like that is really iffy! well i wanted to take the head because it got port polished so yah! could be possible damage!
Old Nov 5, 2008 | 09:27 AM
It could be messed up, theres not really anyway of knowing until you pull the head, i've definately seen it happen though, rod broke, piston came up and hit the head. '90 - '91 B18A heads don't flow particularly well if i remember correctly btw. those engines only put out 130HP at the crank. the '92 - '93s are rated a little better at 140HP.</TD></TR></TABLE>when i take the head off? what will i be looking for to see if it's messed up?
Old Nov 5, 2008 | 09:28 AM
slo_hatch's Avatar
i dont think you can use alot off a da for your eg. correct me if im wrong but the motor mounts will not work in a eg comin from a da...and if you have 3 of them why not just use those?
and btw...you wanna sell your b16 tranny or you got any more hydro b series trannies?
Old Nov 5, 2008 | 09:35 AM
Default Re: LS SWAP IN A EG! (slo_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i dont think you can use alot off a da for your eg. correct me if im wrong but the motor mounts will not work in a eg comin from a da...and if you have 3 of them why not just use those?
and btw...you wanna sell your b16 tranny or you got any more hydro b series trannies?</TD></TR></TABLE>
well i was gonna buy aftermarket motor mounts but i just wanted the axels and shift linkage and stuff thats about all then trash it after! i got the car for only 500 dollars! with 2 ls motors on the side! sorry man thats the only b16 i got!
Old Nov 5, 2008 | 10:17 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaEg_808 &raquo;</TD></TR><TR><TD CLASS="quote">when i take the head off? what will i be looking for to see if it's messed up?</TD></TR></TABLE>
Bent valves and in some cases the outline of the piston in the combustion chamber. Ideally take it to a machine shop and let them look it over.
Old Nov 5, 2008 | 10:31 AM
Bent valves and in some cases the outline of the piston in the combustion chamber. Ideally take it to a machine shop and let them look it over.</TD></TR></TABLE>
thanks man! but i have another question! since im pickin up the da the axels and the shift linkage is what i need for my swap right! because i was gonna buy aftermarket motor mounts! thanks man!
Old Nov 5, 2008 | 10:35 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaEg_808 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man! but i have another question! since im pickin up the da the axels and the shift linkage is what i need for my swap right! because i was gonna buy aftermarket motor mounts! thanks man!</TD></TR></TABLE>
The axles will work as long as you use the intermediate shaft and transmission axle seal that goes with them. The shift linkage i'm not sure about. '94 - '01 defiantely works, as does the '99 - '00 civic si linkage. Honestly if thats all you want out of this car you would be better off just buying the parts you need, it'll cost you less.
Old Nov 5, 2008 | 10:42 AM
The axles will work as long as you use the intermediate shaft and transmission axle seal that goes with them. The shift linkage i'm not sure about. '94 - '01 defiantely works, as does the '99 - '00 civic si linkage. Honestly if thats all you want out of this car you would be better off just buying the parts you need, it'll cost you less.</TD></TR></TABLE>
well the guy im pickin up the car from is also giving me 2 complete ls motors and the gs for 500 so i guess its a good deal! but
Old Nov 5, 2008 | 12:32 PM
cmon guys more input would work!
eg6civic1538
May 29, 2007 04:37 PM
m R g S r
Northeast (Sales)
Dec 4, 2005 08:18 AM
m R g S r
Dec 4, 2005 08:17 AM
ekmotorfiend
Southeast (Sales)
Sep 25, 2005 02:40 PM
integraguy17
Feb 3, 2004 07:31 PM
