Loss of power (acceleration) in car
Old Nov 7, 2008 | 11:01 AM
doubleoazn03's Avatar
Default Loss of power (acceleration) in car
I've notice that my car sometimes feel a little sluggish in acceleration. When I step on it in the morning when its cold, it pulls hard like it use too; but when its like a hot day, it feels a lot slower when I step on it. I changed the oil and filter with amsoil and a mobil 1 filter and also changed the spark plugs with ngk's and using the proper gap of .044. the car came with ngk plug wires as well.
Anyone know what I can do to fix or aid this????? I was thinking of doing those fuel injector cleaner additives. I work at autozone so I get a discount hahhahaha
Old Nov 7, 2008 | 11:19 AM
macson's Avatar
Default Re: Loss of power (acceleration) in car (doubleoazn03)
Car, engine, milage?
Have you taken a look into air and fuel filter recently? Gas millage seem normal? Have any cel's and does it give a little smoke at all?
Old Nov 7, 2008 | 11:57 AM
Default Re: Loss of power (macson)
i looked at the air filter, it seemed pretty clean. The fuel filter, i havent checked that yet. and its a 92 honda civic si with about 180,000 miles on it.
Old Nov 7, 2008 | 12:33 PM
hawjboi's Avatar
check your timming.. when cold the timming is off to warm the motor up but when warm usally hits top dead center.. check the timming..
Old May 26, 2009 | 08:14 AM
SweetDA9_TR's Avatar
let me know how this turns out...im having a very similiar issue..
Old May 26, 2009 | 08:31 AM
civic_driver's Avatar
When it's cold, the air is denser so you get more air in the cylinders, thus more power, and when it's hot, the air is less dense so you get less power. You might get more power when you replace worn out parts but it's pretty normal for that old of a car.
My 99 civic is the same; during cold weather it runs much better than during hot weather.
Old Aug 18, 2018 | 11:52 PM
Ashton B's Avatar
I have a 2008 Honda Civic, I bought the car about a month and a half ago and I have been having problems with the acceleration for about half a month. When I bought it I would barely press on the gas and it had plenty of acceleration, but now I am almost having to have the pedal to the floor to get the same, as well as it just feels bogged down. Also occasionally I will go to press the gas and it feels like it has a dead spot then all the sudden everything is there at once. I know that problem is possibly the throttle body and/or the gas pedal itself, but would that explain the loss of power? I don't know if the car has ever been tuned up at 150k, which I do plan to do, but again don't know if the could be contributing to the loss where it was fine when I bought the car. I got into the car tonight and it kind of sounded like there was a leak in the exhaust, but I haven't had a chance to look into it, but again don't know if that could be as well, I doubt that one cause I haven't been in any situation that I could have gotten a hole, but am open to suggestions. Thanks and any help is appreciated
Old Nov 16, 2021 | 11:14 AM
Gary67's Avatar
Hi, I'm having this issue. Did you ever get it figured out or fixed? Thanks
Old Nov 21, 2021 | 05:59 PM
tamboo's Avatar
10 Year Member
https://honda-tech.com/how-tos/a/hon...ate-tps-374868
also check mechanical timing ie crank/cam alignment.
jumped belt drove me crazy for months .8(
Old Nov 21, 2021 | 08:28 PM
ManuelTwinCams's Avatar
Default Need help. 99-00 Honda Civic ek shell with a 92-95 prelude engine H22
Hey new to this site I need help with a 99-00 Honda Civic ek shell with a 92-95 prelude engine H22 i need my power steering to work I brought the other night and it’s not on.
The guy I brought off said to me it’s a tight fit on with the civic shell but there is a special bracket made for it looking but I haven’t found anything can someone help me I would really appreciate it
Old Nov 23, 2021 | 07:32 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: Need help. 99-00 Honda Civic ek shell with a 92-95 prelude engine H22
Start a new thread and be specific with the details of your car and the questions/problems you're having.
Old Sep 5, 2022 | 09:01 PM
Dis45's Avatar
I'm also having this issue , please how did you go about fixing the problem ?
Old Sep 5, 2022 | 09:10 PM
theYBLEGAL's Avatar
Loved
First step is creating a new thread in the appropriate section of the forum.
This thread is from 2008 and usually everyone that participated has moved on and doesn't look out for post notifications.
Your best bet is to create a new thread, explain your problem, and link to research or similar issues you find elsewhere as examples if required.
Jayk00CivicEx
Mar 29, 2012 10:49 PM
deerman2701
12
Jun 22, 2009 12:09 PM
brutekiller787
27
Feb 18, 2009 04:10 PM
blake22
Mar 29, 2007 05:51 PM
