tach acting crazy... whats happening?
so the past couple days when im driving ive noticed that sometimes my tach needle jumps up and down very fast about 200-300 rpms. it will do it for a second and then stop. i dont hear the engine revving any higher its just the tach jumping. ive owned the car for about a year and a half (del sol with a d16z6 175k) and its never done this before... any idea whats goin on? thanks in advance for the help.
Check your spedo sensor. I've had an ls and my z6 do that. The one with the ls I forgot to plus the cable back in lol and my z6 had coolant leaking on it. So just see if its loose or something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batallic »</TD></TR><TR><TD CLASS="quote">have u changed the dizzy at all</TD></TR></TABLE>
negative
negative
mine did that a while and it was my screw that was on the rotor came out lmao but if its not somethin like that is sometimes means your dizzy will be going out mines doing it now still i figure is because my speedo dont work and that screw was in there HeHe its now lock tighted in there lmao
9 times out of 10 your tach jumping randomly is your ignition module going bad, check the connectors on it. if theres no problem there replace the ignition module or the whole dizzy whatever is cheaper
Originally Posted by biscuit225
It's more than likely your coil. I'd check the connectors for the ignition module also. Make sure they're not loose/corroded...
stealth89hatch
13
Jun 17, 2005 03:25 PM
Average Al
Jan 22, 2004 04:13 PM
team2n1hatch
Jun 17, 2003 02:04 PM
