Thermostat Hose, where to connect?
could u double check just in case ? + should i add antifreeze to the block around the pistons (the space that always has antifreeze) before putting my new head in, or should i just add it through the radiator ?
just put it in through the radiator and bleed the system properly!! youll be hard pressed not to get any water on the pistons which is a no no for the rings..... just make sure everything is dry before installing your cyl head.. i'll double check on that hose today...............
what ? dont understand a thing man.. however, i put that hose on the iacv and i still got a missing hose which comes from the block that i thought went to the iacv but if that one goes to the aicv then this one can't go there as well as there's only 2 spots for hoses and the first one goes to the intake manifold. Where does this hose that comes form the block goes to then? it's got antifreeze running through it and it's like around the oil filter.
Nikoli
Oct 26, 2004 02:40 PM
vtec69
Mar 28, 2003 06:57 PM
