LMAs changed and still knocking
Old Nov 6, 2008 | 07:02 PM
Pagley's Avatar
Default LMAs changed and still knocking
I have a Jdm B16 fullybuilt. Skunk2 Valvetrain, Crower stage 2 turbo cams, Aem camgears, PNP head. Well i recently disassembled the whole motor and replaced every seal and bearing with oem Honda parts. At the inital startup i noticed a knocking coming from the head so i replaced the LMAs with Oem 2000 b16 ones and after starting again its still knocking. My question is what else could it be or did i use the wrong ones or are the cams just to agressive?
Old Nov 6, 2008 | 09:24 PM
Pagley's Avatar
anyone?
Old Nov 6, 2008 | 09:36 PM
slacks's Avatar
Default Re: (Pagley)
you're using a pretty beefy head.. of course it's going to make some noise
make sure it's a bottom end knock before anything else though.
Old Nov 6, 2008 | 11:20 PM
.I.Need.Money.'s Avatar
Default Re: LMAs changed and still knocking (Pagley)
A little noise is normal w/ upgraded cams and valvetrain.
How many miles are on the head?
Old Nov 6, 2008 | 11:50 PM
butter99's Avatar
maybe clearance on the springs
Old Nov 7, 2008 | 05:47 PM
Pagley's Avatar
going to put stock b16 cams in tomm see if that fixs the promblem
Omegax10
Mar 19, 2012 10:31 PM
nhamilton122
May 1, 2011 05:55 AM
Pagley
Nov 7, 2008 05:49 PM
spidy3
Apr 17, 2008 10:09 PM
