speedometer is way off
borrow a gps, see how far it is out, remove the gauges and front glass, gently pry off the speedo needle with two flat screwdrivers, be carefull, place it in the correct place, gently push a bit, not all the way on, you may need to move it again, when you get it right, reassemble the gauge cluster.
It's easy.
It's easy.
faded
Aug 28, 2005 08:18 AM
ferrarifreak93
Jun 5, 2005 10:32 PM
