B16A in 95 ex problem...
Old Nov 4, 2008 | 04:36 PM
TehMan's Avatar
Default B16A in 95 ex problem...
i just put a b16a in my civic and now i am having problems...the idle is surging from like 1500 to 2k rpms and a thick white smoke is coming out of the exhaust...when i hit the gas pedal the motor like shuts down...it doesn't die all the way but it doesn't rev up...and the nipple coming off the back of the vc is shooting air out of it...
i also have a question about a port coming off the back of the motor under the itm...on my ls motor we just had the hose plugged shut with a bolt but on the b16 i rerouted it to another port on the motor that i thought coolant normally went through...here are pictures of the two ports
its the small on right above the black box
and here is the other side off my b18b that i plugged off
and here is where i rerouted it to on the b16 right under where the dizzy is
i also have this plug that i can't figure out...it's right near where the harness plugs into the passenger side of the head..
Old Nov 4, 2008 | 05:07 PM
TehMan's Avatar
Default Re: B16A in 95 ex problem... (TehMan)
i pulled 5 codes
3-MAP
5-MAP
10-IAT
14-IAC
21-VTEC
Old Nov 4, 2008 | 05:43 PM
nemesis25's Avatar
Double check all the wire harness plugs. Make sure that they're not switched around, especially the MAP and TPS plugs. As for the loose plug, it looks like the Intake Air Temp Sensor's. In regards to the hose I think that's a water hose for the Fast Idle Thermo Valve which is attached to the underside of the throttle body.
Old Nov 4, 2008 | 06:30 PM
TehMan's Avatar
Default Re: B16A in 95 ex problem... (nemesis25)
the map and tps was backwards and i fixed it...the IAT is right and the IACV has the wrong plug on it i need to plug it up right...that other loose plug i dunno what it goes too...it only has one wire running to it...the ITA is a 2 wire plug
Old Nov 4, 2008 | 06:52 PM
B16CRXT's Avatar
is it a crank angle sensor? Vtec plug?
Old Nov 4, 2008 | 06:59 PM
TehMan's Avatar
Default Re: B16A in 95 ex problem... (B16CRXT)
not the vtec plug not even close lol
Old Nov 5, 2008 | 07:47 AM
92integraVTECgsr's Avatar
Is that plug only have 1 wire going to it? If so, what color is it? I just double checked, and that is the VTEC plug on my car.
Also that hose you have blocked off, needs to run to the TB. It runs coolant to the TB.
Old Nov 5, 2008 | 07:50 AM
TehMan's Avatar
Default Re: B16A in 95 ex problem... (92integraVTECgsr)
how come that plug doesn't plug into the vtec solenoid on my b16 then?
and that hose was blocked off on my ls...i just ran it back to the motor on another part...there is no port on my throttle body for that hose to go to
Old Nov 5, 2008 | 08:10 AM
Alright, I edited your picture a little.
On your thermostat housing, do you have 2 small ports coming off of it? If you look at the picture, you'll see where the hoses need to go.
Old Nov 5, 2008 | 08:15 AM
alright.. a little more info. this should help you.
the hose from the TB that is going to the metal pipe needs to be going to the Intake manifold. And the hose that is plugged (it is coming from the thermostat right?) it needs to go the metal pipe.
But here is what I would do. Go to the store, get a couple feet of that size hose.
1. Cut a new piece of hose to fit from the TB to the IM.
2. Cut a piece of hose to run from the thermostat to the head and eliminate the metal pipe.
Get what I am saying? That should fix your coolant/hose issues and idle.
Old Nov 5, 2008 | 08:44 AM
TehMan's Avatar
the fitv under the throttle body has a hose coming off of it but it's already plugged up to somethng
Old Nov 5, 2008 | 09:45 AM
what's it plugged too?
and the hose that is coming off the head, that is the one you have plugged with the bolt?
Old Nov 5, 2008 | 09:49 AM
TehMan's Avatar
the one that is plugged is on the LS motor i pulled out of the car before i put the b16 in...i would have to relook at the FITV to see what that hose is connected to...tonight when i get over there to mess with it i'll check and figure it out...maybe post another picture...
Old Nov 5, 2008 | 09:50 AM
can you take me a better picture showing that side of the head to behind the throttle body so I can see all the hoses and ports.
Also take a picture of the thermostat area and intake manifold area where the coolant lines plug up.
Old Nov 5, 2008 | 09:59 AM
ahh.. the picture I edited was the picture of your LS motor.
Alright.. Here is a picture of my JDM B16 OBD1 I got from Hmotorsonline that I put in my 92 integra a few years ago.
See if this helps you.
Old Nov 5, 2008 | 10:03 AM
TehMan's Avatar
i'll check it when i get back to the garage...thanks for all the help...you'll probably see it at IA if i get it done in time or else i'll be in a maroon expedition lol
Old Nov 5, 2008 | 10:11 AM
lol you'll get it done in time.
is that all that is wrong with it?
also, do you have something plug into the VTEC already? because I'm almost 99% sure that plug is for VTEC.
Old Nov 5, 2008 | 10:17 AM
TehMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">lol you'll get it done in time.
is that all that is wrong with it?</TD></TR></TABLE>
yeah i pretty much figured everything else out...other problem is i can't get it to go in gear even when the car is cut off...someone told me it's because i haven't bled the clutch system yet...so i'm going to try that and see if it works...then i just have to throw the passenger side skirt, driver fender and front bumper on and it's ready to go
also, do you have something plug into the VTEC already? because I'm almost 99% sure that plug is for VTEC. </TD></TR></TABLE>
and nothing is plugged in to the vtec solenoid but that plug won't fit on it...i've tried
ZeroTo100
Feb 19, 2015 10:15 AM
thisnameblows
May 30, 2014 08:45 AM
Markb16a
May 26, 2010 02:01 PM
