Valve Adjustment?
Old Nov 5, 2008 | 05:28 PM
Happyfeat2006's Avatar
Default Valve Adjustment?
Does anyone know what the specs are for a 1st Gen. B16 head is? What size feeler gauge should I use?
Old Nov 5, 2008 | 05:30 PM
The_Honda_Guy's Avatar
Default Re: Valve Adjustment? (Happyfeat2006)
Do you by chance have a Hayne's manual for the car? If not, it's the best 15 dollars you can spend if you're going to be working on the vehicle. It lists all (almost all) the specs you will need as well as repair procedures and wiring diagrams.
Old Nov 5, 2008 | 05:34 PM
Default Re: Valve Adjustment? (The_Honda_Guy)
I've got an LS VTEC, so I don't have the book but I guess I'll look into one. I was just trying to look for a quick answer.
Old Nov 5, 2008 | 06:25 PM
Default Re: Valve Adjustment? (honda.lioness)
This is a big help, thanks. By any chance would you know were I could fine ECU Pins.
Old Nov 5, 2008 | 06:41 PM
honda.lioness's Avatar
I am not sure what you mean. I know what an ECU is. I know there are pins on it for electrical connections... You mean wiring diagrams? If so, same site as I gave before.
Old Nov 5, 2008 | 06:44 PM
No I'm talking about the pins that go on the end of the wires that plug into the connector. I'm thinking that I can get them from any auto parts store but I've never seen them.
Old Nov 6, 2008 | 05:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyfeat2006 &raquo;</TD></TR><TR><TD CLASS="quote">I'm talking about the pins that go on the end of the wires that plug into the connector. I'm thinking that I can get them from any auto parts store but I've never seen them.</TD></TR></TABLE>
Great question. Unfortunately, I am not optimistic. As it happens, I am trying to make a DX blank connector for my DX steering wheel into one that accepts the set/resume cruise control switch female connector. I have not found new parts that do this. What I have decided to try is soldering a junkyard LX male connector to the DX's blank's wires.
I posted a query on same here a few weeks ago and no one answered. I suspect there is a lot of (perfectly reliable) jury rigging going on for electrical mods here in swap world.
laloquera916
Honda Civic (2001 - 2005)
May 9, 2016 09:30 PM
TurboSmith421
Nov 4, 2010 11:57 AM
4DRmafia
16
Aug 22, 2004 07:51 PM
crxtacy08
Sep 28, 2002 03:40 PM
