Frustrating Idle/Stall Problem
Old Nov 5, 2008 | 08:47 AM
wanderinglost's Avatar
Default 95 LX - Frustrating Idle/Stall Problem, Won't Start
Hey guys, I'm back...with more problems, haha.
CAUTION: LONG POST!
Ok, so the 95 LX that we have started idling really low a couple weeks ago. If left at idle it would search up and down and gradually decrease. Eventually as the car warmed up it would drop so low that it would stall out.
At first, the car started back up just fine, but then it started to have some issues and would not start right back up. At first, it would just crank for a while before turning over. Then when that got a bit worse, we'd just have to push the gas a lil' bit and it'd start up. But this weekend it finally cut out, stalled, wouldn't start no matter what...ended up having to tow it home.
Now here's the kicker, when the car is running, it runs beautifully. Perfectly fine, no weird noises, no issues...but as soon as ya stop moving, everything goes to hell.
So far we have:
- Cleaned throttle body/iacv
- Ran fuel system cleaner
- Changed PCV
- Changed O2 sensor
- Changed air filter/fuel filter
- Changed brakes/rotors (not really related, but it did help the car from stalling for a little bit)
- checked plugs, they seemed fine, got new ones anyway but haven't put them in yet.
So yeah, that's pretty much where I'm at. This is getting really frustrating and confusing. No idea where to go next, probably going to pick up new cap/rotor and see if that helps any.
Modified by wanderinglost at 8:04 AM 11/7/2008
Old Nov 5, 2008 | 03:22 PM
Default Re: Frustrating Idle/Stall Problem (wanderinglost)
Bump. Anyone? This damned thing has got everyone confused. T_T
Just came back from a walk to advance to pick up cap/rotor and some anti-seize so we can do the plugs. We'll see how it does tomorrow once we have light again. Stupid Daylight Savings.
Old Nov 5, 2008 | 05:25 PM
mikehawk's Avatar
fitv .. also try adjusting the throttle stop a little to get it to idle a little higher
Old Nov 7, 2008 | 07:05 AM
Ok so now it won't even start anymore. Engine just cranks and cranks but won't turn over. Checked it over this morning, it gets spark, but still won't start, even with some starting fluid sprayed into the intake.
Now I'm really at a loss. Gonna check the dizzy and the timing belt next. *sigh*
Old Nov 7, 2008 | 08:19 AM
slo_ef's Avatar
I would check if your getting power to the fuel pump, and if the main relay is working properly.
Old Nov 7, 2008 | 08:31 AM
We'll have to check the main relay. Could it still be the fuel pump even if the car doesn't start with starting fluid? I thought that would have pretty much ruled out fuel as the problem.
Koko4
Oct 9, 2014 06:34 AM
ben1284
Feb 18, 2008 06:17 PM
Mr_ET
Sep 9, 2007 01:35 PM
Outkast95LS
Dec 27, 2004 05:36 AM
