Problem with car wont crank over
Old Nov 6, 2008 | 02:57 PM
ITR.#1446's Avatar
Default Problem with car wont crank over
I have been letting my little bro use my civic and its been driving great until 2 nights ago he calls me up and says the car wont crank at all. I go meet up with him and when he turned the key forward to crank it there was no fuel pump prime, a weird electrical noise was coming from the passenger side dash and when it made the noise the guage cluster lights would dim and flicker like it was loosing power.
So i checked the battery 12 volts
Took the main relay from my r and put it and the fuel pump now primes.
also switched out ecu with another working one.
But when you go to crank it, it still makes a weird electrical noise like something is shorting out and the guage cluster still dims out and flickers. So i disconnect the starter signal wire to see if anything would change and it did. Now when you crank it you can just hear the starter relay click. So i had another starter laying around thinking the one in there was shorting out but still does the same thing.
I am confused on whats going on and was hoping you guys can please help me out here
Old Nov 6, 2008 | 03:45 PM
sp00nek9's Avatar
Default Re: Problem with car wont crank over (ITR.#1446)
i would try the starter next like you said
Old Nov 6, 2008 | 03:48 PM
jeremyrocksursox's Avatar
might be your alternator
Old Nov 6, 2008 | 03:53 PM
wrenchez81's Avatar
Default Re: Problem with car wont crank over (jeremyrocksursox)
^^^LMAO!!! aha ....... NO!!! check your grounds under the the hood..............then check and make sure the power distribution center wires are secure......... then do a voltage drop on the battery!!
Old Nov 6, 2008 | 04:08 PM
ITR.#1446's Avatar
Default Re: Problem with car wont crank over (wrenchez81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00nek9 &raquo;</TD></TR><TR><TD CLASS="quote">i would try the starter next like you said</TD></TR></TABLE>
i change the started out already no difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrenchez81 &raquo;</TD></TR><TR><TD CLASS="quote">^^^LMAO!!! aha ....... NO!!! check your grounds under the the hood..............then check and make sure the power distribution center wires are secure......... then do a voltage drop on the battery!!</TD></TR></TABLE>
thanks ill def check that, i started thinking about that before and i bet its the problem. If not ill check for a voltage drop i am pretty sure all the wires are secured fine. Thanks
Old Nov 6, 2008 | 04:13 PM
mikehawk's Avatar
i got money on a bad ground
Old Nov 6, 2008 | 04:28 PM
ITR.#1446's Avatar
Default Re: Problem with car wont crank over (mikehawk)
Im sure it/hope it is. I only have the trans one on right now and it was stripped out kinda i guess from the previous owner, so just called my brother to have it check it and let you guys know.
Now if it is will this cause the main relay to go if you try to crank it a couple times because i had to replace it fuel pump wasn't priming.
Old Nov 7, 2008 | 10:40 AM
ITR.#1446's Avatar
it was the ground
Mr.Aaron
Apr 21, 2018 04:00 PM
rick_rabies
26
Apr 5, 2009 01:07 PM
ITR.#1446
Nov 7, 2008 10:34 AM
PhantomX
Apr 6, 2008 09:15 AM
hialeahzbg
Jul 12, 2007 01:00 PM
