RPM low at idle WHY? Help please!
Old Nov 7, 2008 | 03:09 PM
FRKWOO's Avatar
Default RPM low at idle WHY? Help please!
jus changed my megan headers, magnaflow cat back, a new aftermarket oem obx converter now the idles at like 500 rpm when stopped at a light or lower and from time to time it almost dies the battery light flashes on then off but the car doesnt completely die. what can be the problem?
Old Nov 7, 2008 | 03:31 PM
wrenchez81's Avatar
Default Re: RPM low at idle WHY? Help please! (FRKWOO)
carbon build up in the throttle body.... try turning the idle bypass screw about 3/4 turn to the left and youll be fine!!!
Old Nov 7, 2008 | 05:45 PM
FRKWOO's Avatar
Default Re: RPM low at idle WHY? Help please! (wrenchez81)
what? dont understand can explain in more detail please thanks
Old Nov 7, 2008 | 07:09 PM
jdmtuner_eg's Avatar
theres a pretty big flat head screw on the tb. You just need to adjust in cause of carbon build up. It usually faces the direction of the tb and location varies.
Old Nov 7, 2008 | 09:53 PM
FRKWOO's Avatar
found it did it improved a little when i driving it for about 5 mins the rpm stays at 1000 then as the motor gets hotter when i come to a complete stop its goes back down to 500 rpm and starts spundering again like before?
Modified by FRKWOO at 11:06 PM 11/7/2008
Old Nov 7, 2008 | 11:06 PM
FRKWOO's Avatar
bump bump
Old Nov 8, 2008 | 02:44 AM
wrenchez81's Avatar
ignition timing advanced ????? any vacuum leaks????? if not take the iacv off and see if the screen is clogged with carbon aswell!!!
Old Nov 8, 2008 | 04:29 AM
SickSi99's Avatar
check for leaks man. make sure everything is on there tight. especially the header and cat. i would suggest taking your tb off and cleaning it out with some brake cleaner.
Old Nov 8, 2008 | 08:15 AM
JunkyardAccord's Avatar
Default Re: (SickSi99)
yeah it sounds like your idle air control valve is clogged
oil catch can would keep this from happening again i believe.
Old Nov 8, 2008 | 10:31 AM
FRKWOO's Avatar
Default Re: (JunkyardAccord)
what's a oil catch can?
Old Nov 8, 2008 | 01:45 PM
Default Re: (FRKWOO)
a oil catch can catches the blow-by that runs back into your intake manifold
blow by looks alot like gasoline and can gunk up your engine
and it also relieves pressure off the crank
Old Nov 8, 2008 | 02:28 PM
FRKWOO's Avatar
where can I find the air control?
Old Nov 8, 2008 | 06:14 PM
FRKWOO's Avatar
now my cars blowing out more smoke with a strong gas smell and water gripping what does it mean?
Old Nov 12, 2008 | 06:04 PM
FRKWOO's Avatar
tried cleaning the idle speed and the throttle body with berryman b12 throttle body clean improved a little but still when the motor heats rpm idles drop to about 200-300 and sometimes the battery will flash on then off. what else can be the problem and what else can i do?
d0wnShiFt
Aug 5, 2018 01:32 PM
FOMULA91
14
Apr 23, 2009 07:04 AM
9ST
Nov 28, 2008 01:26 PM
mountaindewguy
Feb 8, 2005 08:56 AM
B16CRXT
Jul 19, 2004 11:06 AM
