horn not working
Old Nov 7, 2008 | 05:05 AM
zenon8890's Avatar
Default horn not working
hey HT,
my horn stopped working suddenly, i have a 98 civic LX, its was working normally, then sometimes stopped and sometimes worked, i can here the relay clicking when i push the horn button, but no sound, is there a fuse or something or should i replace my horn?
Old Nov 7, 2008 | 05:51 AM
NOFX's Avatar
H-T White Ops
Default FV-QR
There's a fuse diagram thread linked in the FAQ at the top of this section.
Old Nov 7, 2008 | 06:00 AM
ForgetMyNameX07's Avatar
First thing would be check the fuse....second, have someone check the wiring in the wheel, i had that problem with my 97 civic
Old Nov 7, 2008 | 06:49 AM
zenon8890's Avatar
Default Re: (ForgetMyNameX07)
no i told u i can hear the relay clicks when i push the horn button, i had that problem before and i fixed it
Old Nov 7, 2008 | 06:54 AM
SiR18EG's Avatar
Default Re: (zenon8890)
I would also look at the horn itself. It may be a loose connection to it. Somehow the mysteries of stuff never messed with being unplugged never cease to amaze me.
Old Nov 7, 2008 | 07:47 AM
z6hatchboy's Avatar
If you have power to, check the grounds. Horn systems are a short to ground system, they have constant power, but the circuit is completed when you press the button that completes the ground
Old Nov 7, 2008 | 07:58 AM
zenon8890's Avatar
Default Re: (z6hatchboy)
where is the horn ground? i can hear the relay clicks, i guess its the horn or bad wiring
Old Nov 7, 2008 | 05:03 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
'98s and up use the one pin system ('97 and earlier use the two pin). The ground is where the horn mounts to the chassis on the front of the car. If you don't have contact between the two, you will either have no horn or a very odd sounding, quiet horn.
Take the bumper off, unclip the horn, use a 12mm to remove the horn from the core support and make sure there is a clean contact between the two.
Old Nov 12, 2008 | 04:29 AM
zenon8890's Avatar
Default Re: FV-QR (NOFX)
u r a god, i just did what u told and it worked thanks alot
Old Nov 12, 2008 | 06:09 AM
NOFX's Avatar
H-T White Ops
Default FV-QR
lol
Thanks. I just replaced my horn with a better sounding one the other day and some of the coating on the horn shifted and broke my ground on the mounting point the same day that I posted back to you. All I had to do was take the horn back off, brush away the paint and mount it again.
What luck, right?
Old Nov 16, 2008 | 04:42 PM
zenon8890's Avatar
yeah right, i use Hella horn i bought of a 2003 c class benz from a scrap yard lol, nice sound for a 7$
LiL JoN
10
Jun 22, 2010 09:22 PM
tei344
Nov 9, 2007 05:51 AM
Redemption
Jun 24, 2007 03:18 PM
sinister357
May 24, 2005 10:32 PM
spooncivic1
May 17, 2005 08:12 AM
