skunk2 pro vs itr/ctr intake manifold!!!
Old 02-01-2010, 10:53 AM
nikanoras's Avatar
Default skunk2 pro vs itr/ctr intake manifold!!!
hello guys..
i have an ek4(b16a2) with intake/header/exhaust and obd1 reprogram ecu and i am thinking to replace the intake manifold..which one is beter choise? worth skunk2 pro IM the extra money?? if i replace my stock TB with a bigger it will performs better? waiting for your advise... thanksss
Old 02-01-2010, 11:22 AM
93egSLEEPER's Avatar
Default Re: skunk2 pro vs itr/ctr intake manifold!!!
The S2 pro will show better performance at high RPM over the stock unit. If you did the S2 IM w/ a portmatch TB and portmatched to the head that would be the best of any option. depends on how much money you wanna spend
Old 02-01-2010, 11:30 AM
nikanoras's Avatar
S2 plot shows gains up to 18hp and 15lb/ft compared to a B16A manifold at mid range... http://www.skunk2.com/mm5/merchant.m...de=307-05-0280 ..is that true or is a marketing trick??
Old 02-01-2010, 11:43 AM
Crazy Honda Guy
Deetz's Avatar
personally, i call bs on their dyno. I would love for any person to take a p30 manifold powered b16A, dyno it, then swap the manifold and make those kind of numbers!!!!
Old 02-01-2010, 11:44 AM
That will all depends on what cams, header, exhaust, intake and other supporting mode you run with it as well.... not to mention the tune you put on it.
I would look into what that IM was put on. That looks like it was on a well built LSvtec, it was revving to 9k and making power to 8500, not to mention almost 200whp. that can be why they are showing such great gains.
Old 02-03-2010, 12:59 AM
nikanoras's Avatar
bump for more advise...
Old 02-03-2010, 11:16 AM
what else do you want? tell us more about your build/future plans. I personally think unless you decide to build the head and run a set of cams it wont be worth the money.
Old 02-03-2010, 11:29 AM
cc203's Avatar
i dont know if this is much help but i have a dyno book and it shows a stock b16a intake manifold made more power then alot of after market intake manifolds till the higher RPMs
Old 02-03-2010, 11:37 AM
thats what im trying to get at. unless you plan on building the motor to perform at higher rpm it is pretty much a wasted upgrade and waste of money.
Old 02-03-2010, 11:44 AM
cc203's Avatar
x2
em2crusin
K Series
12-15-2011 04:00 PM
JDMCIVIC919
10-11-2011 05:30 PM
92integraVTECgsr
26
12-10-2008 04:21 PM
LD_EGSICK
25
07-31-2003 08:30 PM
Drag-On
10
10-11-2002 05:51 PM
Quick Reply: skunk2 pro vs itr/ctr intake manifold!!!
