Injectors
Injectors
I am finishing my h22 swap and wanted to know which injectors to use.
Which type of injector uses the resistor box? saturated or peak/hold?
someone please chime in because i need to buy them today.
Re: Injectors
so peak/hold would be better for this swap boosting 12lbs looking for 300+ right?
I also heard that some DSM injectors could be used without the resistor box, is that true?
Or is that with saturated DSM also? Im not too knowledgeable on injectors but i do know the resistor box brings the current down.
Peak/hold are what 12 omhs and saturated are around 4? why not just run the saturated since they are closer to stock?
Re: Injectors
peak/hold are low resistance, saturated are high resistance.
what car is the swap going into? what year is your h22? what ecu are you using?
Re: Injectors
you car does not have a resistor box so if you want to run p&h injectors you need to add one. its easier to just run saturated injectors for your car.
NOTE: 94 h22 oem injectors are peak and hold, measure resistance between the two pins to verify. so if injectors came with your swap then you need a box.
as far as the p13 goes, you can get one if you want IAB control and are going to run the h22 in stock configuration. or just stick with the p28 and disconnect the vacuum line to leave them open at all times. also you can add circuitry to the p28 to control IABs as well, your call.
Re: Injectors
Yeah i doesn't stock but i have one. Just trying to see if i could get out of running one with out losing gain by using saturated injectors. with my setup, i want to run either
550cc or 780cc dsm injectors.
with saturated what size should i run for my setup?
Re: Injectors
550's should be great for 300 whp. i made the mistake on getting too big of injectors for my setup lol i have 1000's in my built sohc but don't need them, i have some weird idling issues because of the large injectors
for the price of what you are probably going to pay for those 550cc dsm (not sure if dsm's have 550s) but you could buy a set of RC's
Re: Injectors
and by adding circuitry for IABs i am referring to...
Originally Posted by xenocron.com
How to Install our IABs parts kit in your 1720 or 11F0 OBD1 P05, P06, PR4, P61, PR3 or P28 ECU
1) Install Q17 if not present (goes in directionally, follow other transistors on the board)…writing should face down in pic
2) Install Q34 if not present (goes in directionally, follow shape of white outline) …writing should face down in pic below
3) Remove R135 if present
4) Install jumper wire from Right Hand Side of R135 to Arrow Side of D13
Re: Injectors
As for the injectors, they are p/h dsm's:
http://cgi.ebay.com/ebaymotors/SIEME...Q5fAccessories
but about the circuitry, i dont think im that inclined to work on the board. i tried soldering once before and f'ed up a pretty good p28, so never mind!
Re: Injectors
that link is of new injectors, they are just built to fit a dsm. when we say dsm we are generally referring to used oem 1g eclipse injectors. they are 450cc and p&h and just happen to fit hondas with little mods. they are also cheap.
again, get some saturated 550cc's and you are set for 300whp. no box, no mods. plug and play
Re: Injectors
now they have new saturated injectors that go as high as 2000cc from injector dynamics. check out t1raceparts.com for more info
Re: Injectors
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
so these would be great for my setup then. no box at all..
lsturbo*
08-15-2009 08:50 PM
