my speedo keeps cutting out!
hey i just got an Si cluster and i put it in my eg and it works fine, but about half the time my speedo trips out and either doesnt work or acts sporadic. my original cluster never did this, i checked all the fuses in the car and they are good, any ideas?
Re: my speedo keeps cutting out!
Check to see if the plug going to your speedo sensor came a little lose, you can reach it easy, it's located on the top of your tranny towards the back, try unplugging & reconecting. This happen to me twice, may not be your problem but worth a try.
Go to a parts store and get a chaging system test.
This can also happen when you are just running off the battery and your alternator has since spun it's last voltage. lol
Has happened to me and it was the issue.
the speedo sensor is secure, i tried to remove it then plug it back in and that didnt help, and what do u mean by just running off of the battery? my alternator/battery is running perfectly fine, any other ideas?
I don't know bro. Just trying to give you a lil' insight.
I had the same problem at one point and the alt. was the issue.
Do yourself a favor and go get a free test.
If it's not the alt. at least you'll know you have a good alt.
alrite i tested the alternator/battery with a tester and it works fine, any other ideas that would cause my speedo to cut out randomly?
Seagull Management
If you aren't throwing a CEL for VSS the speedometer head in the cluster is most likely bad. Swap the speedometer head for your original DX one, they are identical (this also lets you retain your mileage.
ok this is a really really common problem with eg clusters....please dont waste your money on a vss there expensive and its not your problem...
the speedo is junk, if you still have your old cluster open it up and carefully remove the speedo without messing with the needle. remove the junk one from your si cluster and replace with the other one....i have done this to 7-8 of my freinds cars, i had it happen a few years ago, spent way to much money trying to fix it....figured out its the speedo itself...after some more searching it seems to be a common problem
LP.
bboyjimpy
16
03-16-2008 06:28 PM
