M/T Bseries Swap: Which Rear mount for Dx chassis?
Hello...im some very quick responses from of the pros. or anybody that might know:
My question: Which Rear engine mount do i use for a b18c1 swap into a Automatic chassis 92 Civic DX?
I will be converting vehicle into Manual Trans at the same time as motor swap.
My options:
1. Use the stock automatic rear engine mount thats with chassis.
2. Use a Civic si manual trans rear engine mount from 92-95 civic hatch si
3. USe a Manual trans Integra 94+ Rear Engine Mount.
Please someone help me ASAP...i have an opportunity to by a integra rear mount soon, and dont want to buy it if i dont need it. Please help.
Thank u..
PLEASE BUMP! It will help
My options:
Thank u..
Re: M/T Bseries Swap: Which Rear mount for Dx chassis?
When i put a 95 LS swap in a 95 civic DX i used all of the integra mounts. I don't think the Civic D-series mounts will bolt onto the B-series engine or trans.
you will want 1994-1995 integra manual mounts for a 92-95 civic, and 96-2000 integra manual mounts for a 96-2000 civic.
if your talking about the mount part that has the rubber in it, theyre all the same. it doesnt matter
if youre talking about the mount bracket you must use a b-series one. on a side note, you will need an aftermarket upper trans mount to put it in the auto chassis. or you can get the bracket from honda for $30 and weld it on the frame rail while you have the engine out.
hey thanks guys for the input. some are one side of the fense and some on the other side. I think imma just try and get a manual d series mount and try it. i guess will see what happens. Ill definetly give the results.
Lei Siew Long
09-04-2001 07:57 PM
