96 OBD2 GSR Swap
Old 02-01-2010, 09:49 AM
solo227's Avatar
Default 96 OBD2 GSR Swap
I did my swap and now im tryna get emissions tested but everytime they hook up the scan tool... Its unable to get a connection... Can somebody help???
I do get a check engine light but thats cuz both of my O2 sensors arent hooked up...
IS it a problem with my harness or what?
Old 02-01-2010, 11:06 AM
B18CivicEJ8's Avatar
Default Re: 96 OBD2 GSR Swap
What ECU are you running? OBD1 ECUs and JDM OBD2 ECUS (which are basically OBD1 ECUs in an OBD2 case) will not communicate with the scanners. Only USDM OBD2A and above will work. Besides, you'll fail anyway cause of your CEL.
Old 02-02-2010, 04:36 AM
solo227's Avatar
I have a ODB2a ECU... Its outta a 99 GSR...
Clearly its hooked up enough to run but why wont it connect to the diagnosis port...
Old 02-02-2010, 04:55 AM
97twodoor's Avatar
If you're using a 99 GSR ECU then it's OBDIIb. So you will need the OBDIIb ECU to OBDIIa harness adapter.
luis_ej8
11-28-2011 11:03 AM
TwotoneC1Da9
01-28-2011 02:03 PM
92integraVTECgsr
05-03-2010 03:55 PM
CivicFerioSiR
08-25-2003 08:22 AM
Quick Reply: 96 OBD2 GSR Swap
