D1z6 idle problems!!!
I have a 95 ex and i put a new d16z6 motor in it because the other motor blew. I got the new motor put in fine and everything put in its place. Well i went to start it and the idle jumped from 1k to 2k. so i ran the computer and it came back as code 14 which is IACV well i cleaned it out and put it back on the intake manifold. Started the car up and still idled from 1k to 2k. Ran the computer again and code 10 came back which is the air intake temp sensor. The sensor had a crack in it so i replaced it and started it up and it idled high but didn't start jumping until the engine warmed up. Ran another computer test and code 7 came back which is TPS. I replaced the TPS and now it idles at 3k and doesn't jump. I also tried to adjust the throtle screw and it didn't help. Can somebody give me their thoughts i would really apreciate it!!
Re: D1z6 idle problems!!!
i had the same prob with my eg6 but its the IDC valve its like 25bucks @ the auto zone or maybe you should just get it from the dealer...its rite on top of the intake its between the firewall & intake manny
Well I found what my problem was... huge vacuum leak. So I'd recommend checking for a vacuum leak before you throw parts at it like I did...
BoostnEK6206
10-19-2007 11:23 AM
