What B-Series Tranny is this?? Cable or Hydro?
Can someone identify this tranny for me?
I was told it was a Hydro B16 but i was looking @ mine and the small tubing below is a little thiner as you can compare from both pics below.
and here's the unknown b-series tranny, tubing is a little wider.
Besides that, everything looks the same. Here are some more pics..
Drop your input, thanks H-T.
here's another view from the bottom.. Hydro or Cable? thats my concern
Re: What B-Series Tranny is this?? Cable or Hydro?
we need some letters and numbers bro. looking at a chunk of aluminum is hard to ID w/o a code. what is the code on the sticker? OR clean it up and look at the stamp on the tranny case that is come w/ from the factory. those pics are helping with nothing.
thats the thing, theres no sticker or vin. i'll check the stamp on the tranny as soon as i get home.
oh alright, i just glanced and saw it... now i see its the starter. why is the barcode sticker removed? are there vin tags on it?
that "unknown tube" is just a breater valve.
I dont have any details on the tranny since i picked it up from a friend who was cleaning his garage and he was told it was a B16 tranny.
It looks identical to my b16 tranny, but then again so does every other b series tranny out there. we need codes. period
I have the S4C tranny out of the 99-00 si. I added a qualife LSD from a ITR to it though. ITR tranny w/ a longer final drive for the freeway for less cash.
yeah thats what i have in my car @ the moment. the breather valve is a little thicker and smaller thats why im confused.
Thats a hydraulic transmission.
you can see where the shift linkage hooks up, as to what B series hydraulic transmission it is. Well you are going to have to open it up and count the final drive gear and/or 3rd and 4th gear.
alright so i jus ginished picking up a 99-00 civic si casing and the tranny i have is identical to the casing..
they both have YSK-2 stamped on the top. thanks to all who replied.
Good stuff, But to be 100% sure, I would do a quick tooth count. ( as that can be the genereic obd2 transmission casing, meaning 99-00-01 integras could of used that casing ). But then again. You already own it and it will fit, so i guess install it and enjoy.
Thanks dude. Im gunna install this one for now and build me a backup one since i cracked the casing on my other b16 tranny. LSD and brand new casing on the way.
HERE'S WHAT MIAMI STREETS DO TO YOU... I'VE ALREADY RAISED THE CAR UP
southernSCHEME
Transmission & Drivetrain
02-01-2010 12:45 PM
