oil pan gasket
Re: oil pan gasket
drain the oil, remove the oil pan, the remove the oil pan gasket (itll either be stuck to the oil pan or the block), then clean the **** out of the oil pan, administer the new gasket, and reconnect the oil pan to the block.
Re: oil pan gasket
take the exhaust manifold out first. drain oil. remove flywheel cover on tranny. unbolt pan bolts 10mm. install in reverse order. buy the haynes manual. thats how i did mine about 2 months ago on my d16y8 too! it helps.
Re: oil pan gasket
k thank you cuz it def looks more complecated then unbolting the oil pan and replacing it. so i just need to remove the exhaust manifold and flywheel cover then im good to go.
y install in reverse order?? and is there a certain pressure i need to bolt the oil pan back up
Re: oil pan gasket
obviosly you havent done this on a y8 its a lil more difficult then unbolt replace and bolt back
Re: oil pan gasket
generally the exhaust hugs real close to the oil pan so i can't imagine trying to take the pan off and putting the seal on properly, with the header still in place.
Re: oil pan gasket
yeah i just got a guy explain the whole thing for me on another site ill be sure to do a write up on this for everyone thanks
projectej8
11
04-03-2005 02:45 PM
grizoove
12-04-2002 12:03 PM
