96 ls swap is bogging down help
Re: 96 ls swap is bogging down help
you need to supply some more info so someone can try to help you out
what do you mean by bogging down? when driving or what
ok im starting over, i have a 97 civic dx that has a d16y7 in it. i swapped to a 96 ls im using the civic wiring harness and ls ecu that is p75-a04. im also use a o2 from a 97 cl so i do not know if that it the problem or what but i started it up and it was idling bit f##k up . it seem to be run hell rick because i can smell the fuel in the air .when i try to give it gas it just bogs down but when slowly giving it gas it rev up and down.
