need help with pcm relay
i have a 95 honda del sol with 310k mi. it began turning over but not cranking. the fuel pump relay was not pulling in. i took it to a mechanic and he replaced the main relay. it worked for about two days. i took it back to him and he replaced the relay and also replaced my ignition sw and wiring harness. it ran for about a week. i then started testing myself and found i was losing the ground through the ecm. i can jump the return side of the relay to ground and it will pick up. i traced continuity from the relay(ground side) back to the ecm and it was ok. i had it once again towed to the mechanic where he says it has been cranking ever since. i know it is only a matter of time before it quits again. any suggestions would be greatly appreciated!
wambus
02-12-2004 08:40 PM
