D16z6 ecu question
D16z6 ecu question
I have a 93 eg hatch with the mini me swap dz16z6 with manual trans and the retard that put it in used the wrong ecu and got it to run but it fails emissions.....my question is I wanna put in p28 ecu and all new engine wiring Is it possible to get a p28 manual ecu and the harness from an auto and make them work?? Ive Searched already....believe me I searched
Re: D16z6 ecu question
why would you get a complete new wiring harness? i believe it should work with the one you have in there all you should need is a new ECU
your best shot for the wiring harness would probably be online or at a junkyard
No junkyard in my town has it.....i also just looked it up I have a p75 obd2 ecu in there and I dont know if the wiring would match.....would it??
Well, first off your car is a 93, which is obd1. So you have the wrong ECU in there to begin with. I would try getting just an obd1 ECU and if your still having problems then look into the wiring harness but im almost positive it should be fine once you get an obd1 ECU in there
im not sure just by looking at the ecu. did it come with any paperwork? also i wouldnt worry about what the old one is you gotta just make sure you get the right one you need
if i were you, id do what im doing, and just buy a brand new one off ebay, when you buy it you tell them your engine setup and they tune it for you before they send it to you
