Fuel+spark+ cranking over motor='s not starting?
i just pulled my motor had to replace oil pan gasket and clutch and a motor mount. put everything back in plugged it all back up turned the key to the "on" position a couple times to build up fuel pressure. turned it over it started and died out. than when i go to start it it just turns over. i checked for spark i got it. i cracked the banjo on the fuel filter and fuel sprayed ot the top of the garage so i have fuel pressure and fuel. but it wont start any ideas. somsone said vapor lock but i have only heard of this on older accords and when its hot outside its like 20 degrees here. any ideas would help need ot get this thing moving in a couple hours ha
Re: Fuel+spark+ cranking over motor='s not starting?
timimg belt was never off and i never touched the dizzy i never checked about power ot the injecotrs but pulling my plugs out theres a faint smell of gas on them not as strong as it should be but its their
jondrethegiant
08-07-2009 10:05 AM
00trdtaco
06-03-2008 11:30 PM
brokenojoke
03-09-2008 10:22 AM
