h22a types
h22a types
how do i find out what h22a i have? motor says h22a that is all. i was told it does have a lsd trans. so how do i know what car my motor came from?
thanks
thanks
Re: h22a types
anybody?
also it has a blank off plate on the egr. not sure if its stock or not. i might should mention that the valve cover has been polished so i don't know what color it was.
Re: h22a types
Chances are you have a jdm h22a standard 200hp and 160tq. Do you have any pictures? I can confirm it by looking at the intake manifold, header, valve cover etc..
Re: h22a types
If it says p13 all over the place...it means you have a regular Jdm h22a, the m2b4 means that its an lsd tranny.
p5p should be the type S
Re: h22a types
the intake says pgmfi it has a header not the stock mani. it seems like the head said p13. is this the 10.6:1 compression motor? the ecu is square and has p13-a12 on the side. i think its a usdm ecu. also along with the egr being deleted, the vacuum to the butterfly valve is disconnected for some reason. so it looks like i need to look into it more. is there an electrical drive to the butterflies? sorry i forgot the actual word for the butterflies.
Re: h22a types
Re: h22a types
so i need to do a swap to a p28 converted to p72 or p72 with a h22a tune.? i'm searching in the prelude section now trying to figure it out. i do not like not being able to tune. I'm spoiled with my Tahoe and hptuners.
Re: h22a types
If the motor is stamped h22a without a number after "a" then its the jdm motor which is 10:6 compression. However if you get a number after h22a such as h22a7 "7" indicated Euro R model which is from Europe and not JDM.
They removed the egr from the intake manifold? is there a plate used to block the missing egr valve? Also check to see if the intake manifold still has the IAB box underneath the manifold or the "dual butterfly box".
If you like you can actually use a obd1 p72 ecu from the Gsr instead because it also has the IAB function on it just in case you plan on using that IAB box.
Afterwards you can get this ecu chipped and tuned
Re: h22a types
gotcha on the ecu and eng. its a jdm eng with lsd trans and a usdm ecu.
there is a blank off plate on the manifold.
not sure where the iab box is but i will look and see what i can find. would there be a blank off if it was gone?
i have a p06 with the correct board for modding into a p28 with iab control. i'll be using that.
Re: h22a types
Actually the accord Euro-R was intended for the Japanese market. The Accord Type R is for the European market. I dont know why lol.
http://en.wikipedia.org/wiki/Honda_T...pe_R.2F_Euro-R
And these are some if not all the H series motors around the world.
http://en.wikipedia.org/wiki/Honda_H_engine
Re: h22a types
i found the wiki link the other day when i was searching around. it just sucked for me because the damn valve cover has been polished. i think i'll sand it up and paint it black. it looks old and like a bad polish job.
tim.simpson
12-25-2001 10:36 AM
