climate control
Old 01-29-2010, 07:16 AM
dmeconitas's Avatar
Default climate control
Will 96-98 climate control fit into a 95 civic?
Old 01-29-2010, 07:18 AM
97ej6dx's Avatar
Default Re: climate control
are you talking about the dash peice with the vents and climate control or just the actual control box?
Old 01-29-2010, 08:43 AM
dmeconitas's Avatar
the actual climate control. The thing that lets you turn on the heater and a/c. My current climate control is all busted up and missing ***** and I can get a 96-98 relatively cheap compared to the 92-95
Old 01-29-2010, 09:11 AM
ca-rs's Avatar
Not without extensive mods
Old 01-29-2010, 09:16 AM
dmeconitas's Avatar
by extensive mods do you mean wiring? I just want to replace the climate control itself, not the dash the climate control is housed in.
I want to put this in.
I have been trying to find rear view of the two climate controls to see what the wiring looks like but I cannot find any. I know people put the 92-95 in their crx.
Old 01-29-2010, 09:21 AM
ca-rs's Avatar
Will not mount to the dash properly and the wiring is different. I have both and can send you pics of the back if you like but it won't help. They mount completely different and are diff shapes.
Old 01-29-2010, 09:42 AM
dmeconitas's Avatar
Yea I would like pictures of both. You could post it here or shot me an email dmeconitas@gmail.com
Old 01-29-2010, 09:45 AM
ca-rs's Avatar
OK, What all do you want pics of? Just the connectors on the back of the climate control? Would you like a pic of the wire harnesses that connect to the climate control? It maybe tomorrow before I can get you the pics, Its about 3 below zero here and I don't feel like digging them out of the garage.
Old 01-29-2010, 10:21 AM
dmeconitas's Avatar
The back view of the climate controls and the connectors. If you have the wire harnesses a pic of that would be cool too. Yea if it was that cold I wouldnt want to be in the garage either. There is no rush.
Old 01-30-2010, 05:00 PM
ca-rs's Avatar
OK, It appears I was wrong on the wiring. I took a eg harness and put in on the EK Climate control. Fit perfect and has the same pins. I can't believe I didn't notice that before. Anyhow, while that is the same as you can see the EK control is much larger & diff shape that the EG:
Old 01-30-2010, 06:13 PM
dmeconitas's Avatar
yea it is bigger. But I can get it for 15 bucks and I cant find any thing cheaper than 45 for 95. So I will just pick this up and put it in. Thanks for the detailed help. I just started to get a cel and its 9. I know its cyp cylinder position. I cant find the trouble shooting in the helms I have, but I can in the helms for my rex. Would the testing procedures be the same?
Old 01-30-2010, 08:55 PM
H-T White Ops
NOFX's Avatar
You should be able to find the correct 92-'95 Civic climate control for pretty cheap on eBay or the junkyard. First gen Odysseys should also work IIRC.
Old 01-30-2010, 10:17 PM
dmeconitas's Avatar
naw ebay is pretty expensive also. I never see any Odyssesy in the local pick n pull.
Kaiyoken
08-12-2008 09:26 PM
VeilSide_Mas
07-20-2005 01:18 PM
beav
11-21-2004 08:13 PM
Quick Reply: climate control
