iacv??
iacv??
ok im about to get and eg with a b20b4 in it and it needs to have the iacv changed hes giving me the new one i was just wondering if anyone can tell me how to do it??
Re: iacv??
its on the back of the intake manifold by the throttle body. Disconnect the sensor plug, undo the 2 coolant lines, and undo the (2) 10mm bolts
Re: iacv??
nope not to replace the IACV
you will have to make sure coolent doent run out of the lines since the IACV is connected to the coolent lines to cool it.
Re: iacv??
It's a very simple thing to replace, if you spill some coolant, which you most likely will do anyway just fill it back up and bleed the system you'll do fine man, good luck.
waynesumner
10
06-07-2013 10:30 AM
Vagitarian
23
10-21-2012 08:27 PM
