B16 swap but check engine light is on
Hi i did a complete swap on my civic its a 93 civic coupe swapped a b16 motor in it and also changed the ecu which was off a del sol and wired the v-tech however my check engine light is on and it reads the following
1) ELD (electrical load detect)
2) map sensor
3) Knock sensor from cylinder
Also the v-tech only kicks in if i reset the computer which means if i turn the car off and back on then drive but as soon as the light come back v-tech stops working anyone has any ideas on how to get rid of the check engine light thanks a lot
2) map sensor
Re: B16 swap but check engine light is on
ELD, should be taken care of by getting a engine bay fuze box out of the car that the ecu came out of or a 94-95 integra. Change the map sensor, and either wire up the knock sensor, or change it out.
thanks for the reply but i have a quick question from which car should i get the map sensor from del sol or SIR?? thanks
