how much is this worth?
hello all, i know im probably posting in the wrong thread, but i felt likt the for sale threads are really for people selling their stuff, i'm just trying to figure out how muh i can get out fo this:
- '97 Del Sol trailing arm assembly for rear disk brake swap on '92-'95 civics.
i was reading the rear disk swap threads on here and the guy said you could use the 93-97 del sol rear disk setup just fine with 99si ebrake lines. so i went out and sourced one. its the entire trailing arm assembly, incuding the brake calipers, and brakes, etc.
the only thigns that are wrong are the disks need to be replaced, obviosly, along with the pads, and the ebrake cables cuz i told the guy to cut them off (i didnt know better at the time)
also, i bought a 40/40 prop valve and i have the brake master cylinder from the same car.
so how much do you think it is worth?
the only reason im getting rid of it is cuz i sold my hatch that i was going to put this on and im getting a teg.
Thank you,
-Inso
Thank you,
-Inso
Resident Gearhead
Re: how much is this worth?
IDK man you can get all that stuff from a salvage yard for cheap, atleast around here. I guess I wouldn't pay more that $175 for all of that stuff.
If the trailing arms had new bushings, rotors and wheel bearings that would be a different story.
And I am not a big fan of using used brake master cyls.
cool thank you. i was gonna put it on craigslist to see if someone wants it or some ricer kid has more of his parents money to spend than he knows what to do with. i kind a figured somewhere around the $200 price range. thank you. mods, this post can be closed/deleted. i got the info i wanted. thank sguys again.
HairyHarry
12
07-09-2019 11:51 AM
Type_R_Nammer
Suspension & Brakes
02-22-2010 08:04 AM
Hythrax
01-22-2003 07:58 AM
