B16 Idles at 100rpm, bogs with gas
I was bleeding the clutch to get it to shift properly after I rebuilt it. This seemed to help, I started it, and it cold-idled at 1300-1500 like normal, shifted to R and backed out, my car seemed to shift now after bleeding the line. I drove a circle around the yard shifting to 2nd, 1st and N. It got harder to shift and within about 5 gear changes, same old problem, the gear shift would NOT move with the engine on. I figured I'd bleed it again.
I shut off the engine to shift to reverse and head from the driveway to the garage, because if I start it in gear and let out the clutch, it works-ish. This time I started it up, and the car sluggishly started up at 100-150rpm, the alternator idiot light comes on cause the idle is so low. If I gave it gas, it would just BOG horribly and want to die even more! UNLESS I let it idle maybe 30 seconds at this crappy 100 "dying-like" rpm, and VERY,VERY SLOWLY give it gas, it sort of sluggishly gets up to 1000-1500rpm, then bogs again.
Nothing changed between the 1500rpm drive around the yard, to the shut-off and start up 15sec later.
I'm getting a white smoke from the exhaust. Not a lot, less then when you start the car on a cold morning, but certainly noticable.
Re: B16 Idles at 100rpm, bogs with gas
Think the head gaskets not seated properly and its getting coolant into the cylinders?? I'll check it out when I get home. Its strange that it worked at 1500, for a good minute run around the yard. Shut it off and 10 seconds later started funny. I shut it off and started it maybe 3 or 4 more times and each time, same bogging and low idle issue
