94 GSR front and rears in my 00 coupe??
Will the gsr front and rears fit in my coupe? I searched and it looks like if i swap the inner seat rails the fronts will fit all 4 holes. Does anyone know about the rear?
Re: 94 GSR front and rears in my 00 coupe??
i have been debating on doing this in my hatch and from what i have read the rears will have a gap all the way around. If you can find the bottom portion of the rear from a 4 door integra there will be like a 1" gap instead of a 2" gap on each side.
Crazy Honda Guy
aww, you were talking about seats.....your title was vague
The fronts will with just switching the inner rail,very easy!!!
The rears, will not fit at all
You can use a 4 door bottom and then everyone i know that has this has switch seat pans, put the civic pans on the gsr foam and fabric.
A DB Integra rear seat will fit I think. The 4 door Integra has a similar seat to coupe Civics, Hatchback Civics and 2 door Integras have pull pins on either side of the top of the back seat to fold down where as coupe Civics and 4 door Integras have a key that unlocks in the middle to fold down. Also switching the inner rails will work to line up all 4 bolts but the seats will lean slightly outward since the outer Integra rails are lower profile than the tall Civic ones. Most people (almost all) won't notice the lean unless you make it known, I had some in my Civic like that for a while.
Yoitshector
09-22-2011 09:01 AM
carbonlaced
05-24-2006 02:32 PM
OrangeBoost
11
03-31-2005 12:32 PM
Problemo
01-13-2004 03:05 PM
