firewall plug questions?
Okay guys i finally did a wire tuck and shaved bay. I removed the fusebox moved to the glove compartment and put all the break lines under the dash as well. I called honda and got the AC plug. But now i need where the fuse box wires went through the fire wall and on the passenger side where the headlight wires went through the fenderwell and also the two that had the main wiring harnesses on both sides. Honda says they only have the AC plug, so wheres everyone getting the other ones from? Thanks for the help.
Re: firewall plug questions?
https://honda-tech.com/forums/honda-acura-28/shaved-tucked-customized-engine-bays-pics-theory-discussion-1693934/
Check through this and you should find it towards the middle of the thread. Hope this helps.
Use the rear bumper grommets off a 2000 Ford Mustang, they fit both sides perfectly, they are like 3.00 a piece at any Ford dealership, I will see if I can find you the part number.
http://www.k20a.org/forum/showthread.php?t=47488 This is my buddy's link, he has tons of these.
https://honda-tech.com/forums/showthread.php?t=1693934
EJ1 wilcox
21
01-07-2008 11:49 AM
