EG w/B18c1 Stock Inate Manifold: Option for Air Intake!! Help
Specs:
92 DX
97 B18c1, all stock
So when i did the swap, i bought a GSR stock air intake box and arm. Well after installing the motor, i tried installed the airbox and arm and its not anywhere near a direct fit.
SO...my question is which air intake can i buy, OEm or aftermarket that will install properly, look clean and function properly. Right now i just have the Gsr arm on with the Filter, and its making my bay look like ****!
Thanks guys!
92 DX
97 B18c1, all stock
Thanks guys!
Re: EG w/B18c1 Stock Inate Manifold: Option for Air Intake!! Help
I'm pretty sure the stock eg box with the integra tubing.
If you want an aftermarket intake just get a gsr one, and make sure its a gsr one if your using the gsr intake manifold
i tried that...the diameter of the airbox outlet is smaller compared to the inlet of the gsr intake arm.
Any other solutions out there?? Anyone with this actual experience?
Companies like aem make intakes just for gsr swapped cars.
may be others.
or you could always buy a different intake manifold.
may be others.
THE ONLY ONE I COULD FIND WAS THE AEM HYBRID, WHICH IS NOT CARB LEGAL AND EXTREMELY EXPENSIVE FOR WHAT IT IS(A WATER PICKUP TUBE). i HAVE TO SMOG THE CAR COMING THIS JUNE SO NOW I GOT TO DEAL WITH THAT. THANKS FOR ALL THE FEEDBACK GUYS.... LET SEE WHAT ELSE OTHERS THINK.
Well then modify a integra/civic stock intake, or again buy a skunk2 or something intake manifold, and use a stock intake if you please.
I have an eg with a gsr swap, and I wen't with a cai, (used aem short ram twice in previous swaps) and this is by far better. (hot weather doesn't bother it like a short ram would) Also if it is done right, and don't floor the car through a puddle you don't have to worry about hydro-locking.
I got the fujita cai for 94-01 gsr and it worked with slight modifications =]
Goodluck!
http://www.f5air.com/ You may want to contact them to double check, in the past I don't believe they were, but they might be now. Oddly enough when you go to the testimonials link everyone on there is from Cali lol. Good luck, I am glad to live in the central us thats for sure. You could always go w/ Injen Cai, I know they are carb legal and it is the same design as Fujita, due to a couple of guys who left Injen and created Fujita.
318 Curves, 11 miles
I don't have a great picture of mine, but here's what I have:
I used an LS arm, cut off to the correct length at one of the bends, and my 00 EX airbox with a K&N dropin. Looks OE and works great.
^Nice is that a b18c5 I spy? hehe Looks good, but I guarantee it won't sound as good as a CAI, I love the whine. Now just gotta get my jackson racing installed =D.
b18c5 doesnt use the same IM as the gsr so i think you are just seeing a red valve cover.
OP, AEM short ram for a gsr will work and is CARB legal. but isnt your engine swap illegal in CA anyways? you are using an engine from a different make and model. Or do they let you slide since honda/acura is essentially the same company?
And yes, an AEM short ram would work fine too.
on my gsr swapped civic i did the stock intake box and piping to a bigger cupler and clamped them down works perfect
**** that Ek bay looks clean. Yeah i live in Cali, as above poster stated...you can get bar'd as long as motor is a newer than the year of the car, and ALL emission are there. Im having some wiring issues with my Purge Coltrol Soleniod right now,so i gotta fix all that before Bar'ing. Thanks for all the input guys! Cheers!
just FYI just cuz it has a carb sticker doesnt mean it will pass you have to buy anything carb for the year computer your running not the motor im BARing my gsr in my civic right now and that was my only prob my intake was Carb for my 97 motor and he failed me cuz he said it needed to be carb for the 95 computer i was running sence my civic is a 95
