obd2 ls into eg question
Ok. I've been reading quite a bit about this because I found an obd2 ls dropout for dirt cheap. Should go well with my eg hatch. I read that you can use EVERYTHING on the obd2 motor including the harness and it will plug right into the eg cabin harness. But you need an obd1 ecu... such an obd1 p75 and it will run fine.. I have also read you shouldn't do it. can I do it no problem? Who has done this? And did any problems come up? Thanks in advance.
Seagull Management
Re: obd2 ls into eg question
Whoever told you it shouldn't be done, or couldn't be done didn't know what they were talking about. The only issue you may have is if you use a '00 - '01 Integra harness you will need to add 1 wire for the tach signal if you have a tach, thats it. '96 - '99 harnesses require no modifications at all.
jdmanglerking
03-29-2010 02:10 PM
1990hondaHF
06-08-2003 07:04 AM
