Cyberdyne digital boost gauge setup?
Just installed a cyberdyne digital boost gauge, Wiring is 100% i went over it 3 times, not to mention it fairly basic. As for the warning light setup, It states that you must connect the dimmer wire to 12v to activate the setup mode then you turn the gauge on and using a screw driver select the psi value you wish for the gauge to flash at. Then wait 30 seconds disconnect the 12v to the dimmer and turn the gauge off once you restart the car it should be set... Well that does work lol Ive tried 10 times now and i can select the value for the warning then once the 12v is taken off and the gauge is turned off and turned back on it continues to just flash the number 0.0 and the flashing does not stop? Anyone used one of these or had a similar issue with the warning light setup? I noticed after searching for instructions they all seem to vary slightly and certain steps are reversed which kinda concerns me, Either way ive tried 3 different ways ive read to get the gauge to stop flashing and work properly and nothing... Any experience with this gauge would be greatly appreciated. thanks
