code 14 high idle and stumbling
Old 04-18-2010, 07:37 AM
bless341's Avatar
Default code 14 high idle and stumbling
okay guys I have a 97 civic dx. The only things ive done to the car has been y8 intake manifold, 99 gsr throttle body, headers, intake, and a obd1 conversion harness with a p06 dx ecu. Problem is the idle is extremely high and the car stumbles when driving. I've already set the tps to 0.5 v closed and 4.5v at open throttle. Coolant system is bled. Performed 3 wire to 2 wire iacv. I know the iacv works because there is voltage on both sides. Dont know what to do help please!
Old 04-18-2010, 07:41 AM
Civicfanatic_09's Avatar
Default Re: code 14 high idle and stumbling
Code 14 is Idle Air Control Valve, on the back side of the intake manifold, next to the throttle body.
Old 04-18-2010, 07:44 AM
bless341's Avatar
already swapped the iacv with another one even cleaned it still does the same thing
Old 04-18-2010, 07:45 AM
Check you wiring then, you may have a break somewhere, just get a flow chart and check it.
Old 04-18-2010, 07:51 AM
bless341's Avatar
wouldnt the car shut of if I had a break? I FOLLOWED the instuctions on ff-squad and the car ran fine for a week or two than started going crazy
Old 04-18-2010, 08:15 AM
No, it would run fine with the Cel on, it will just idle like crap.
Old 04-18-2010, 03:22 PM
bless341's Avatar
tried what u told me cant find anything wrong with the wiring. The car shuts off when i pull the plug on the iacv
Old 04-21-2010, 05:16 AM
bless341's Avatar
found the problem , bad ecu
i.
49
02-17-2014 12:53 PM
Efjams24
07-22-2012 02:00 PM
dth0ng69
11-11-2009 09:16 AM
99GreenEX
12
02-22-2008 09:54 AM
Problemo
01-29-2006 04:16 PM
Quick Reply: code 14 high idle and stumbling
