D16Y8 - Is this the correct part for the PCV valve?
D16Y8 engine.
In the picture above, I believe the valve attached to the hose is the PCV valve? And if so, do I have the wrong part?
Re: D16Y8 - Is this the correct part for the PCV valve?
yes that is the pcv ,..and you have the wrong one the one you need is strait not 90 degrees looks like its a bit shorter and thicker to ,..... i would just take the one in the hose up and get one just like it,....
try blowing air thru the pcv or sucking air thru the rubber hose side. if air goes thru its not a pcv valve. if it doesn't then its a pcv valve.
Guys, if you have a D16Y8, when you go to auto shops, tell them you want a part for 96 Del Sol Si. That's how you get the correct parts. If you just tell them it's for 92-95 or 96 to 00 civic ex, they will sell you parts for Z6 or Y7. They are in some cases not same parts.
This is only for engine related parts only.
Yea, they gave me the 90 degree one at the auto store, i put it on not realizing.....does it really matter?
