94 civic rear brake disc conversion?
Hey all, I work in a wrecking yard and a 94 del sol just came in. I was wondering if I could take the rear disc brakes and slap them in my 94 civic hatch? If so do I want the whole assembly or just the knuckle? Thx for your help
Re: 94 civic rear brake disc conversion?
yes you want the trailing arms, the brake lines, and the hub, disc, calipers, and i believe thats it. and it should bolt right on...
you also need the e-brake cables, and proportioning valve. if you use the original prop valve the rear brakes will grab before the fronts do. you can re-use the upper and lower control arms from your car or from the sol.
stryker gs
Suspension & Brakes
14
12-19-2012 05:27 PM
